I've got a title block with mtext and attributes.
The text shows correctly in ACAD 2020 and 2019.
In 2021 the text is significantly wider.
These screenshots are both taken directly after opening the same file.
Any ideas what the cause might be?
2019/2020:
2021:
Solved by cadffm. Go to Solution.
Check the shape of the "C" for example, it is not wider, it's another Font!
Thats normal if ACAD is not able to use the right Font.
Open your file, press [F2] and read about which Font is missing!
*.shx Fonts are AutoCAD files, you need to set a supportpath the the locations where the *.shx files are, or copy your *.shx to a Supportfolder.
*.TTF are Windows-Fonts, which you have to install on your windwos.
Sebastian
i think that your text lose Width Factor . would you try if BATTMAN command can help you ?!! try to Synchronize your attributes and see if any changes .
Imad Habash
I usually just dismiss that message manually.
Just going through the process, it only brings up 2 missing line styles not the missing font but F2 shows the missing font?
Is this behaviour correct?
It would probably be more useful if they made the missing font discoverable from the warning prompt like those missing linestyles and missing xrefs are.
Thanks for your help
