Text selection is reverse ?? first selected text is come at last. and last selected text come first. I Excel Sheet to put text on this. Plz Help.
parwez.khan
parwez.khan
(defun c:TEDIT ()
(setq sset (ssget '((0 . "TEXT"))))
(setq sslen (sslength sset))
(while (> sslen 0)
(setq ent (entget (ssname sset (setq sslen (1- sslen)))))
(redraw (cdr (assoc -1 ent)) 3)
(prompt (strcat "\nOld text: " (cdr (assoc 1 ent))))
(setq nt (getstring T "\nNew text: "))
(redraw (cdr (assoc -1 ent)) 1)
(if (> (strlen nt) 0)
(entmod (subst (cons 1 nt) (assoc 1 ent) ent))
(princ)
Kent1Cooper
Yes, that's an approach that counts down from the end of the selection set.  It can be done by counting up from the beginning instead, for example:
(defun c:TEDIT ()
  (setq i -1); index number [so that first pass uses i = 0]
  (repeat (sslength sset)
    (setq ent (entget (ssname sset (setq i (1+ i))))); start at index 0, count upward
Kent Cooper, AIA
parwez.khan
Thanks bro. for Help.
parwez.khan
Can you write full lisp with your condition please..
