Text problems
Text problems
Text problems
pinaki.rajak
Can you please attach your file where these text has been written, Will do some research on the problem and given you solution if any.
Check your Text font.
The command is STYLE.
Edit Text font that you want.
Alfred.NESWADBA
does not look like text objects, more like a hatch.
When you select such an object and look to the property window ... does it say it's a text or a hatch?
If hatch you might change the pattern to "SOLID", but that does not give you a text object, it only looks like that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
cadffm
Testing with TEXT not MTEXT, what font is set in Textstyle?
It could be a customize SHX Font
Sebastian
