Text problem
Text problem
Text problem
I have a problems with text, that is different in two files. The files are coming from two computers (I dont know CAD version on them), but they used the same template from the beginning. So what is a problem: the same text, with the same font, text height and Style is a little different, like its bold in one case, but it isn't. I'm attaching these two files here. In file 2ASH-62-00-MPS-117_Site_Design_V1 the text is OK. The problem is in file 2ASH-62-00-MPS-132_Site_Design_V1. Please help 🙂
Alfred.NESWADBA
Can you please show a screenshot with both drawings side-by-side?
For me I don't see that big differences between these 2 drawings and the display of the text objects.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Here is my screen shot. It's small different, but the client dont like this...
Alfred.NESWADBA
try these steps in *132*-DWG:
_UCS
_OBJECT
     ==> select the MTEXT object
_PLAN
_CURRENT
... is the text now not "that bold"?
- alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
I'm curious: why are you using font overrides in your MTEXT instead of defining the font you want to use in the text style in use in your text?
Emmsleys
Did alfreds step help with your issue?
If you use a different font are the results the same?
Sarah Emmsley
Technical Support Specialist
Emmsleys
Please select Accept as Solution if any post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
