i want my text to be in the middle of the line with gap and i cannot find any solution for that.
see picture from Autocad
And in Plant 3D this is Possible
AutoCAD
Plant 3D P&ID with SLINE:
Solved by ВeekeeCZ. Go to Solution.
Can you use an MTEXT? Mtexts, unlike pain TEXTs, have a Background mask property.
If it's possible in Plant, then it's an enhanced entity. Plain text does not support it unless you want to put a black rectangle (wipeout) behind it.
I suggest to try Background mask as shown below for mtext .
Imad Habash
Use Middle-Center justification, or in the case of plain Text, Middle justification may give you a position you like better, and put the insertion point on the Line/Polyline. With plain Text, use the TEXTMASK command [read about it in Help for options in size, color, object type]. With Mtext, in the Properties palette you can turn on the Background mask, which also has options.
something more "Automatic" 🙂
and i cannot find how it is working i have lots of Lines it is P&ID
Perhaps this free app?
https://apps.autodesk.com/ACD/en/Detail/Index?id=8403098009239569515&appLang=en&os=Win32_64
