Text of dimensional constrains is not centered,
JamaL9722060
JamaL9722060
Despite the fact that the style of the dimension is set to be center, the dimensional constrains sounds not to respect this property. The text is located at the end of the dimension line
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
0 Me gusta
Responder
1.255 Vistas
22 Respuestas
Respuestas (22)
TheCADnoob
are any dimension overrised set?
Also have you made the changed to the alightment after the dimension was created?
CADnoob
0 Me gusta
JamaL9722060
Thanks TheCADnoob.
I repeated them and now they are centered
Jamal Numan
0 Me gusta
TheCADnoob
Excellent!
If you would mark it as the answer so it can be used for future reference :cara_con_una_leve_sonrisa:
CADnoob
0 Me gusta
JamaL9722060
The issue is not resolved! I just repeated making the dimensions again!
Not sure why the texts at first were not centered while they are then centered knowing that the same dimension style is used
Jamal Numan
0 Me gusta
TheCADnoob
Ok, i misunderstood your previous post.
Would you be able to provide the file?
CADnoob
0 Me gusta
JamaL9722060
thanks. it is attached
Jamal Numan
0 Me gusta
TheCADnoob
def odd.. changing it from annotative to dynamic puts it in the right spot then it moves again....
CADnoob
Pointdump
Jamal,
Why are those dimensions showing a lock symbol?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
0 Me gusta
JamaL9722060
Correct. Why do we have this behavior? Is it a bug?
Jamal Numan
0 Me gusta
JamaL9722060
Hi Dave,
This is contains dimension.
Jamal Numan
TheCADnoob
Its not a bug. THe reason they don't move back is that their position has been changed manually. The text placement is not at the extension line like you would see in a style but rather aligned with the end point per user input. so when you change styles the style is applied and then the manual user positioning overrides the text style. This is why it does not behave this way when new constraint dimensions are added. To fix the current drawing all you need to do is to remove the manual positioning of the text. after that it will behave like you were thinking it should.
CADnoob
0 Me gusta
JamaL9722060
Thanks. How to center all the texts in one go?
Jamal Numan
0 Me gusta
TheCADnoob
Select one of your dimension then Select similar > Dim text position > home text
CADnoob
TheCADnoob
If this problem has been resolved could you please mark it as solved so that others can find it in the future.
CADnoob
JamaL9722060
I’m not able to get the same as your context menu to choose “home text”.
Jamal Numan
0 Me gusta
TheCADnoob
Ok, try this Once you have them all selected hover over the text grip. Select reset text position
CADnoob
0 Me gusta
JamaL9722060
Suppose that I need to do it for one object. I failed to get the context menu when hovering over the grip! What might be the issue here?
Jamal Numan
0 Me gusta
TheCADnoob
try typing
_ai_dim_texthome
CADnoob
0 Me gusta
JamaL9722060
Hi TheCADnoob,
The command you have provide worked fine. However, I would prefer to approach this command from context menu as this command is easy to be forgotten
Jamal Numan
0 Me gusta
