TEXT NOT APPEARING
TEXT NOT APPEARING
varshaMALXV
Observer Observer
TEXT NOT APPEARING
varshaMALXV
Observer
Observer
Hi All,
I have encountered an issue using AutoCAD, I have labeled my rooms on the plans, and for some reason, it is not visible in my base file even when the assigned layer is turned on with the appropriate text size.
However, when I X-Ref the plans, the text appears on my plans.
Does anyone have an idea what might be wrong? Please let me know.
Thanks in advance for any suggestions.
Patchy
Is it an annotative text and without correct scaling?
varshaMALXV
Observer
Observer
This is the current settings of the text. I was able to retrieve it from an old superseded file. Please let me know if I can change anything for the text to appear.
Thank you.
paullimapa
this tells me that your text is annotative and is for scale 1:50:
To see your annotative text:
Set ANNOALLVISIBLE to 1
Paul Li
IT Specialist
@The Office
Patchy
varshaMALXV
Observer
Observer
@paullimapa Thank you. Setting ANNOALLVISIBLE to 1 worked.
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
