Anuncios
Text, Lines in model space are very dim
No aplicable
Everything was fine until my CAD froze and I had to end task. Upon opening the same file all my work inside the model space has become very dim (see picture attached). I have no clue how to resolve this. The text on my title block in paper space is fine, it's bright.
0 Me gusta
Responder
1.948 Vistas
10 Respuestas
Respuestas (10)
TheCADnoob
Is there a chance your model space stuff is an xref? if so check your fade control:
https://www.cadlinecommunity.co.uk/hc/en-us/articles/360000103657-AutoCAD-2019-Xref-Fade-Control
If its not that you can look to see if the layer is locked and the locked layer fade control is set. If it locked try unlocking it. If you need it locked try changing the fade control:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
CADnoob
0 Me gusta
RobDraw
What were you doing when it froze? Some sort of reference editing.
Rob
0 Me gusta
s.borello
Are any of those layers locked?  Have you checked out layer fade options?
No aplicable
The layer is not an Xref and it isn’t locked. ☹
0 Me gusta
No aplicable
No, I had numerous files open (maybe 5 MB each and about 4-5 of them). It froze and I closed out of it through task manager and opened the file back up and it changed by itself. All files are this way now. Any new lines drawn are drawn very "faded"...it looks like it is Xrefed but it's not.
0 Me gusta
No aplicable
None of the layers I am drawing on are locked. They are the usual settings.
0 Me gusta
imadHabash
would you check your drawing Visual Style ?
Imad Habash
pendean
Community Legend
Community Legend
restart your PC yet?
0 Me gusta
RobDraw
Again, what were you doing right before it "froze"? This could point to a solution.
Rob
0 Me gusta
TheCADnoob
as @s.borello  mentioned have you looked at your transparency control on your layers?
CADnoob
0 Me gusta
