Whenever I type something in as MText, and I use any punctuation that is either higher or lower than the actual text, such as a slash or an apostrophe, the vertical spacing of that line changes to accomodate the punctuation. That means with multiple linesI usually end up with uneven vertical spacing. Is there any way to change it so that larger punctuation doesn't affect vertical spacing? Or is this just a quick with multiline text that I'll have to deal with if I don't feel like using regular Text?
For reference, I almost exclusively use the romand font, but I've found that nearly every font has this issue.
