AutoCAD Forum
Text label extraction from DWG file
4 REPLIES 4
3108 Views, 4 Replies
Hi everyone,
                      I want to extract all the text lables in the drawing avaliable as .dwg file using python and filter those text as per my wish and load to a .xls file.
4 REPLIES 4
Michiel.Valcke
I think you can do what you want purely with AutoCAD functionality.
the commando _DATAEXTRACTION can do what you need and deliver it directly to an .xls file.
I hope this helps.
in reply to: Michiel.Valcke
Hi Michiel,
                  Thanks for replying , but data_extraction command will give only the entity tag name, but i actually want to extract the text labels in the diagram, not the entity name or number of blocks.
Michiel.Valcke
Could you share an example .dwg? I'm not sure if I understood your original question correctly.
I thought that if you selected to extract the 'value' then you will get the actual contents of your labels. This should work for all kinds of text objects.
Lemme check... i can't share .dwg file because it is confidential data. Let me try and get back to you later.
