Text inside block to remain constant height when block is scaled?
tcoppens84SWP
tcoppens84SWP
I want to create a block made with text objects that will remain the same size in the model when the entire block is scaled.
For example: I always want the text inside a block to appear 1/8" tall in the model space. When the block reference is scaled up to 1.25 in the overall model, I want the text to be scaled down 1/1.25 so that the text remains 1/8" tall while the other objects are enlarged by 1.25. Scaling the block reference down to 0.8 will scale the text up to 1/0.8.
Is there a way to create a function inside the "Text Height" property of a text object that will scale its height to the inverse of the "Scale X" or "Scale Y" property of the block instance it belongs to?
pendean
Community Legend
Community Legend
Annotative Text Styles is what you seek to setup and use for your block attributes text: here is an overview in HELP https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-u...
