Text height problems
Message 1 of 10
Hi I am having an issue with my text height. I am plotting a 1/4"=1'-0" drawing and I am not sure what my text height should be so it plots out the correct size. Any idea of what the size of my text should be so it plots out at the correct scale?
Replies (9)
Message 2 of 10
Patchy
Text height doesn't have anything to do with plotting, its height is based on viewport scale when you use Annotative.
Post a snap shot of what you have and let's see.
Message 3 of 10
It's my dimension scale text. I attached the final combo so you can see my dimension scale. Like I said it's being plotted at a scale of 1/4"=1'-0" and the dimension scale doesn't look large enough.
Message 4 of 10
Patchy
Post your .dwg and let's take a look.
Message 5 of 10
I attached it.  Thank you for your help
Message 6 of 10
Patchy
8.5x11 is too small and 11x17 won't do it
Choose 24x36 would fit Capture.JPGthose scales.
Message 7 of 10
scot-65
Plotting at 1/4"=1'-0" tells me that you are plotting in model space.
As a go-by, we use a 4 inch text height for our "regular" text, but plotting at a different scale (for instance 1/8 scale) will result in text being too small.
I have seen "Regular Text" as large as 6 inches. Establish a standard and stick with it.
Explore "Strong Text", "Small Text", "Small Drawing Title" and "Large Drawing Title" as basic text object types for your template (5 in all).
Is the STYLE of the text in question assigned to a height greater than 0 (zero)?
If so, the SETVAR TEXTSIZE does not come into play.
You might need to tweak your dimension variables so as align to the current text style. The name of this variable is DIMTXSTY.
(setvar 'DIMTXSTY (getvar 'TEXTSTYLE)) should do it.
To fix existing dimensions, command -DIMSTYLE "Apply" and select the objects.
Is the STYLE assigned a height equal to 0?
If so, play with the SETVAR DIMTXT.
(setvar 'DIMTXT (getvar 'TEXTSIZE)) should do it.
To fix existing dimensions is also command -DIMSTYLE "Apply".
As a reminder, text styles can either be assigned a height equal to zero, or assigned a fixed height greater than zero. Each has it merit, however TABLES do not like the assigned height greater than zero text styles.
To fix existing single-line text, highlight and open the properties floating window or command SCALETEXT.
[untested for those who want to challenge]
Hope this helps.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 8 of 10
I'm going to change it and see what happens. Thank you for your help.
Message 9 of 10
M_Hensley
The old school method for determining text heights for each scale is to divide 12 by your scale then multiply that by the 1/8" text height.
So 1/4"=1'-0" would be 12/.25 = 48. Then 48 x .125 = 6
Message 10 of 10
