Text Height in properties
No aplicable
How do you change a single text height when the text height doesn't show to the properties list?
0 Me gusta
Responder
932 Vistas
7 Respuestas
Respuestas (7)
ennujozlagam
@Anonymous hello, select the text > right click > properties, please see attached. thanks
0 Me gusta
No aplicable
Thanks for the reply, but the Text Box is not showing in the Properties palette. How do I bring that up?
0 Me gusta
ennujozlagam
@Anonymous hello, try in the command promp type MO. thanks
0 Me gusta
ennujozlagam
@Anonymoushello, if still doesn't works, try to install latest updates, service packs and hot fixes from autodesk and see if helps. thanks
alternatively you can refer to this LINK.
0 Me gusta
Alfred.NESWADBA
Can you please show us a screenshot what you see in the properties window when you have selected  thar entity?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Hi and Welcome to AutoCAD Forum,
>> ...but the Text Box is not showing in the Properties palette. How do I bring that up? <<
make sure that you select only the text and without any other object.then type Ctrl+1 while selecting text object . a properties dialog will appear go for text pane and check if it's expanded well form the ( - / + ) symbol and as shown in the below image.
Imad Habash
0 Me gusta
No aplicable
HI
go to text style dialog box (ST).
Create new style with required height.
then come to model space and select text.
then press ctrl+1 for properties
now change style to new style from text section
you can also apply bold, italic and bold italic for text from text style dialog box
0 Me gusta
