Text height in mm's
Text height in mm's
Message 1 of 8
Text height in mm's
I want to print text that is 35mms and using Arial Narrow style. What are the settings that I need to choose to be able to do that?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
in case you plot with scale 1:1 ==>
  • Create a textstyle using font Arial.
  • Create a text with height 35 (in case your drawing units are mm)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
How about printing this text to be 35mm on paper? What settings do I choose for A4?
Message 4 of 8
Alfred.NESWADBA
It does not depend on your paper format.
If you print 1:1 then you have to chose 35 as text height (as long as your drawing untis are mm
BTW: have you tried it? You can try to set it to 35, then print and measure (you can print to PDF too). Would have been faster than asking and waiting for an answer.
If you think your setting is correct and it does not work then please upload the dwg-file so we can see your layout, your viewport scale and your text.
- alfred -
Alfred NESWADBA
Message 5 of 8
I have tried measuring the height of each letter when I printed and it's roughly 25mm not 35mm, my scale is 1:1 and the text height is 35mm and in the options my units are also in mm's. I'm thinking it might be the print option e.g Limits, Window etc..
Message 6 of 8
Alfred.NESWADBA
as I mentioned for that case: can you please attach your dwg-file?
- alfred -
Alfred NESWADBA
Message 7 of 8
Here you go.
Cheers
Message 8 of 8
Alfred.NESWADBA
as the layouts are default I guess you are not using layouts to plot (which you should, it's better than plotting from modelspace).
Looking to the modelspace plot settings: your setting is to plot NOT 1:1
- alfred -
Alfred NESWADBA
