Text frame for Attribute text
Sujan.Maharjan
Sujan.Maharjan
Hi, I am trying to use mleader which I attached to a dynamic block which had a text frame stretchable but I cannot with Mleader. What is proper solution for this situation.mleader_help.png
"Revit Lies in the tension between what we want to do and what can be done!"
TheCADnoob
I believe dynamic blocks are converted to dumb blocks when used in multileaders
Have you tried using a text frame to frame the text?
CADnoob
Sujan.Maharjan
I Need Text frame on the top text only. I need to extract data as well.
TheCADnoob
Ok that complicates it.
I would be tempted to bypass the multi leader route and build a dynamic block that behaves like a multi leader.
If you dont wish to go that route i would suggest setting up different custom multi leaders that can handle different string lengths. So if the sting that needs a block is under 5 characters you would have one type of custom multi leader, if its under 10 and over 5 it uses a longer framed text multi leader and so one.
CADnoob
Sujan.Maharjan
I tried to make a dynamic block version. Any suggestions for improvements. And How can I scale like Multileader for other scales without making it annotative?
TheCADnoob
I might try chaining some of the dynamic elements to reduce the number of grips and look into parametric constraints.
I would hope over to the dynamic block forum and ask if they have any suggestions:
https://forums.autodesk.com/t5/dynamic-blocks/bd-p/154
CADnoob
