Text format Changes
naidukbim
Text format Changes
naidukbim
Hi There,
When edit the title block, text format is changeing like below.
kindly help me to fix it.
@amarkonathala
#Autocad
0 Me gusta
Responder
923 Vistas
12 Respuestas
Respuestas (12)
Alfred.NESWADBA
just guessing: the font is not found and so a replacement font is used.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
naidukbim
Hey There ,
When i edit the block , That text it self changed like that dear.
0 Me gusta
Alfred.NESWADBA
I understood that, and my guess (as long as we don't have more information) is the same, fonts may be missed.
- alfred -
Alfred NESWADBA
Kent1Cooper
Does that mean that the text was correct before you edited it, and changed only when edited?  If so, it suggests that the problem is not a missing font.
Kent Cooper, AIA
0 Me gusta
amarkonathala
Try to open in Latest Autocad Version or Else use True View to Convert it
pendean
Community Legend
Community Legend
STYLE command, start it and fix all the defined text style in your file to match what your titleblock source DWG has for each.
If you don't know how to use STYLE command here is an overview / tutorial https://autocadresources.autodesk.com/the-autocad-blog/text-settings-exploring-the-features-and-bene...
samspade
When you say "edit the title block" do you mean fill in the attributes or actually edit the block with block editor?
0 Me gusta
Kent1Cooper
That as a possibility also raises the question of whether the text was correct before editing -- they said "When edit [not "when insert"] the title block, text format is changeing," which suggests to me that it had not yet changed before editing.
Also, @naidukbim, is this a Block with Attributes, as I think we are all assuming, or possibly an Xref that you are editing with REFEDIT, or independent Text [or Mtext?] objects?
Kent Cooper, AIA
0 Me gusta
naidukbim
Hi..,
Its automatically changed ,  when i was open the block.
0 Me gusta
naidukbim
0 Me gusta
naidukbim
 Mtext
0 Me gusta
RobDraw
Share the file to end the guessing game.
Rob
0 Me gusta
