text disappears when i plot
I try to plot drawings but some of the things I've drawn don't show up in the plot. for example any new doors I draw on disappear and any multiline text I put on doesn't show up in the plot.
I've attached pictures to show what's happening.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
My first guess to this problem is that perhaps these objects that don't plot are on a non-plot layer.  Is it possible to share a sample file so I can take a look? It would also be helpful to see your Plot Stylerr file (STB or CTB)
John Vellek
Here is the cad dwg it just the doors and the pink text
john.vellek
Hi @Anonymous,
I ran AUDIT, Purge, and -Purge>Regapps on your file. It found 11 errors in Audit. I think this might be the root of the problem.After doing those steps I plotted to PDF and everything appears in the plot.
John Vellek
