Anuncios
Text different between our drawings and vendor drawings
Thomasbatson
Thomasbatson
We are using 2021, I am a normal ACADE user but have a text question.  I use standard notes normally, I pasted them into a vendor drawing and they were looking weird.  To test, I open a new drawing, copy those notes from the vendor drawings to our normal template and they look fine.  As you can see in the image there is 1 note where the FURNISH looks different than the note above it even though they are both ROMANS and .0938 size.  I am just not too familiar with this so hoping someone has some suggestions for me to look at.
Thank you for the help.
0 Me gusta
Responder
Soluciones aceptadas (3)
968 Vistas
11 Respuestas
Respuestas (11)
whitney_jeff
Solución aceptada
Thomas, your image was not uploaded.
Sometimes in MTEXT the style/font of the text can be different from the actual defined text style.  Open the text and highlight/select the word and the font will be shown.  That may not be the case here
0 Me gusta
Thomasbatson
Oh crud, sorry...attached.
0 Me gusta
Thomasbatson
And, meant to press reply not accept.....I did open the text and highlight them and they both say ROMANS and .0938
0 Me gusta
whitney_jeff
Yeah, check the properties in both mtexts, looks like one is actually bigger than the other
0 Me gusta
whitney_jeff
Solución aceptada
Check the character width too - on the text formatting bar it's the last drop down on the right
0 Me gusta
Thomasbatson
Highlighting them both and displaying the properties shows that most everything is the same except the contents and position.
0 Me gusta
whitney_jeff
can  you post the actual vendor dwg? (in version 2019 or below?)
0 Me gusta
Thomasbatson
Yes, attached
0 Me gusta
whitney_jeff
Solución aceptada
The character width in the 2nd note is 1.00, and in the first note it is 0.800.  Change them both to 1.00 or 0.800
0 Me gusta
Thomasbatson
Oh, I kind of thought that was in the properties tool bar, I didn't actually use the drop-down in the formatting panel.  Sorry to be a little dense, just anything outside of electrical I flounder a little bit.  Thank you for the great help.
0 Me gusta
whitney_jeff
No problem, glad I could help.  Tons of things I don't know in ACAD!
0 Me gusta
