Text appearing bold
Text appearing bold
No aplicable
Can someone please tell me what is up with this text and why is it blurry? See attached. Only does it when inserting a table using a data link.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.142 Vistas
9 Respuestas
Respuestas (9)
Alfred.NESWADBA
does it look different to my screenshot?
When you plot your dwg-file, is this table/cell/text also look blurry? If yes can you please plot to "DWG to PDF.pc3" and show that PDF?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
pendean
Community Legend
Community Legend
Nothing blurry about your table text here either, in your file or if I insert it into one of my own, even though all your fonts are manual overrides and not the base definition of your text style.
Any chance you are experiencing a font substitution?
0 Me gusta
No aplicable
I didn't manually override anything. Thanks how this table comes in. I wont accept the table style.
0 Me gusta
No aplicable
"It" wont accept the table style. Disregard my last
0 Me gusta
BeKirra
I have the same display as Alfred's.
I notice that the text style "Standard" sets to "simplex" font but the "Standard" texts on the table used different font comparing to "simplex".
In other words, the texts in the table are all with the style of "standard" but the texts use "Calibri" font.
This explains that you see the texts are bold on the table.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
pendean
Community Legend
Community Legend
Forgive me, but is the problem the text is "blurry" as you stated (which it is not) or just the fact that it is now a font other than your default simplex.shx font? And you want your simplex to show only?
Your table is also linked I see (RS-8-B-213-PK-PK2-C510_A.xls), what font is being used in your spreadsheet program? Calibri by chance? Linked tables means you cannot really edit them too much in AutoCAD.
Do you need to maintain the link?
0 Me gusta
No aplicable
We are trying to use the data link file to drive the BOM in our ERP system. This is all new to me. But yes, the bold looking text is what I was referring too. In short, I need the BOM to look identical to all our other DWG BOMS. Needs to look like the attached BOM.......if possible?
 Forgive me, but is the problem the text is "blurry" as you stated (which it is not) or just the fact that it is now a font other than your default simplex.shx font? And you want your simplex to show only? YES
Your table is also linked I see (RS-8-B-213-PK-PK2-C510_A.xls), what font is being used in your spreadsheet program? Calibri by chance? YES Linked tables means you cannot really edit them too much in AutoCAD.
Do you need to maintain the link? YES
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Thanks for the answers.
Red this from Autodesk, I believe it is what you are looking for https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Format...
No aplicable
That's it! Thank you sir
0 Me gusta
