Multiple people in my office have been having issues with the justification on single-line text elements when using AutoCAD 2023 or 2024. Note, this issue does not seem to occur on version 2022, so that is the version we have typically been using.
The issue doesn't happen all the time in 2023/2024, but sometimes the text will randomly offset from it's supposed justification point, without any obvious input from the user or change in properties.
An example is show below. This text is supposed to be justified bottom centre, and it previously was displaying correctly, but since one of our staff edited the file using AutoCAD 2024, it now displays the text offset to the left of the justification point.
As soon as you double click the text to edit it, it snaps back to its correct justification, so it's easy enough to fix each individual occurrence, but I have not been able to find a fix to prevent it happening in the first place, short of simply remaining on 2022 and not using any newer versions of AutoCAD.
This issue also seems to affect attributes in blocks as well, though I don't recall seeing any instances of multi-line text being affected. Attributes are not as easy to fix when this issue occurs with them, because double-clicking them does not have the same effect as it does on single-line text.
I have attached a DWG file with an example of the problematic text if that helps with troubleshooting.
Any help would be greatly appreciated,
Cheers, Jonathon
