Text alignment issue
Message 1 of 9
I have a couple files where my center justification on my text is offset. When I double click the text to edit it, the alignment corrects itself.   My issue is I do not have the time to double click all the text in the drawing to get the justification to rest. Is there anyway to update them all at once? I've tried regen and reopening.
Replies (8)
Message 2 of 9
imadHabash
i open your CAD file and i have not noticed your issue . please send another CAD file with one text that describe your issue ?
Imad Habash
Message 3 of 9
Please see attached image of the issue. We use a custom font not standard to autocad so may not open correctly if you do not have the font installed.
I have never had this issue before this job. One of my drafters fiinished it and this is what I get when I open it. Just really dont want to have to edit every item of text this is happening with.
Message 4 of 9
pendean
Community Legend
Community Legend
What's the font? I am unable to replicate the problem in your file otherwise.
Message 5 of 9
Attached.
Message 6 of 9
s.borello
did you double-click text and see what's going on?  I experienced the issue.
Message 7 of 9
I have been doing that and it goes right back to normal
 I also noticed it is happening with any justified text. As soon as you double click it, they go back to the correct justification. Just kind of tedious to have to do that line by line....
Message 8 of 9
vinodkl
Running "RECOVER" on the drawing file did solve the problem of justification. Though there were no errors found in the drawing when recover was completed. Seems strange.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 9 of 9
Thank you, That works.
I am still uncertain what caused the justification to do that. Never seen it happen before. There are 3 files like this for this job and they are all like that. I will see if the next job from this detailer does it as well.
