Hi All,
Thanks for reading my post, hope ya'll are having a great day!
Since I installed Autocad 2018 and began using it, I have not been able to save any of my drawings. I am relying on autosave in case of crash which does not give me a warm fuzzy. Also, I am set in my ways after 20+ years and I manually click save...often! I did not realize just how often until I started getting this notification and it's cut my productivity in half and makes me want to take up smoking again. The notification explains options 1-3 but do not tell how to get there. I've search all I know to search and the only thing I keep coming up with "This drawing contains objects that are not supported..." is to save as DXF, exit, open, save as DWG, which does not work.
Is there a way to find out what those custom, non-supported objects are or does anyone know how to fix this problem?
Thanks in advance,
Christy
Solved by john.vellek. Go to Solution.
Hi Christy,
What happens if you use -EXPORTOAUTOCAD? Does that fix the issue? Can you attach one of your files as a sample for me?
Can you tell me what to do after -exporttoautocad? What option?
Let me see if I can find a small file after I get my work done. I've gone back to 2017 to keep my productivity where it needs to be.
Thanks for helping me.
Hi @c.root.crd
use the filename option. it will write the file contents to a new file and leave the original intact.
Please send me a file - if it needs to be private I can arrange that too.
-EXPORTTOAUTOCAD worked. Am I going to have to do this to all of my drawings? That's a nightmare. Do you still want a drawing? If so, private preferred.
HI @c.root.crd,
If you work with any of the vertical products, you will have to weather this activity for a bit until the Object Enablers become available. If you do not need the proxy information then you could use a Macro to do the EXPORTTOAUTOCAD.
Hi John,
I tried to send the file this morning and received this message.
Message not delivered |
Your message couldn't be delivered to ******your email****** because the remote server is misconfigured. See technical details below for more information. |
The response from the remote server was:
554 5.7.1 <****your email*****>: Relay access denied
Also, I do not know what a macro is unfortunately. I am almost self taught (when I was in college our teachers were learning with us back in '95) and have not been able to keep up with a lot of the additions over the years.
HI @c.root.crd,
I made a short video for you on how to create an action Macro. I hope this helps to speed things up for your process.
In looking at the file you sent me, I did not have a difficult time saving it from AutoCAD 2018 although it did have proxy objects in it.
I did notice that Audit found an error and -PURGE>Regapps was able to remove 650 Regapps. You might see if these maintenance steps help the behavior.
