Anuncios
Template color palette
silviu.bunu
silviu.bunu
Hi to all.
I want to start by saying that I am new to this forum and please do not be too harsh on me.
I want to mention that I don't know if the template is corrupt, if the colors were not inserted from the very beginning corresponding to each layer or if the software is to blame. This template was opened on computers and on all 3 I had the same result. The problem I have with the template is as follows: as you can see in picture 1, the color of each layer is white. Each layer should have a specific color as in the second picture. Can you tell me why the color palette of all the layers is white? Is it possible that the color palette is not set from the beginning? I use AutoCAD 2019 and 2021.
0 Me gusta
Responder
Soluciones aceptadas (2)
647 Vistas
2 Respuestas
Respuestas (2)
cadffm
Solución aceptada
the pictures a re useless because all layers from PIC1 showing the same color in PIC2
No difference :cara_guiñando_un_ojo:
In Picture1 are only layers with name B* and all with Color7(white/black)
in Picture2 we see the same, all layer with name B* are set to color7
The other layers from Pic2 are not listed in Picture1
But: If you are working with AutoCAD, than the simple answer is:
The one who created the setup saved the layers with this colors, nothing else.
Open the DWT
Command: OPEN, change FileExtension to DWT, navigate to your template you are using
open the DWTfile, check color of Layers..
Sebastian
0 Me gusta
imadHabash
Solución aceptada
Since you have two different layer names in your attached images we can not give a proper answer .
we can not tell !!
Imad Habash
0 Me gusta
