AutoCAD Forum
Taper/Loft Issue
1 REPLY 1
vlokito
232 Views, 1 Reply
Taper/Loft Issue
Hi All, I am trying to create a 3d model from these two joined polylines with loft. Note that one cross section is a bit smaller with the other one. With loft I am trying to make a tapered model of the object, basically it "shrinks" a bit to one of it sides. I was able to do this multiple times with other cross section shapes, but I have no luck with this one. Can anyone help? Thanks!
Tags (4)
1 REPLY 1
parkr4st
in reply to: vlokito
those are not closed plines.  Those are splines.  pedit and convert to plines and the loft will complete
AutoCAD Inside the Factory
