Taking too much time to open a file
No aplicable
When I try to open 1.5 mb file which is contained 2 xreff taking too much time to open. onceits open I checked on the commad line show given in the screen shot.my Sytem configuration is
Ram-32GB
system type- 64bit
processor- intel(R)xeon(R)
Please help me to sort this issue
0 Me gusta
Responder
1.455 Vistas
7 Respuestas
Respuestas (7)
imadHabash
Hi and welcome to AutoDesk Forum,
What about latest Service Packs and Hotfixes?
Does it takes long if you open the file from other PC?
Does it happened with every drawing you open it? if the answer is "NO" try to open the xref files itself and PURGE and AUDIT them.
Imad Habash
Alfred.NESWADBA
what is "ANZACAD"? It seems to be an application on top of AutoCAD, so try to disable that app and see if loading of files can be reduced.
Additionally to the advices by @imadHabash I would ask you to copy your drawing and xref files to your local disk, then disconnect from network and try to load the file from the local drive, is that faster?
At least one additional question: are your files stored in the current format (DWG 2013)? Having set the default format to older dwg formats can result in such performance issues.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
Thank u so much Mr. Alfred for your reply..
ANZA CAD is our company toolbar,and files are saved in 2013, I try everthing except desible the ANZA CAD..lets try
0 Me gusta
No aplicable
Thanks for your reply mr. imadhabash
my service pack is 2
I didn't install hot fix, I told it to install, after installing hot fix I don't feel any changes ,and also I have problem in image also
0 Me gusta
john.vellek
Hi Joshigopinathan1982,
Welcome to the Autodesk Community!
Is it possible to attach your drawings to a post so I can see if there is anything in the drawings that might be causing this behavior?
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
Can you try a Reset settings to Default to see if that helps? This will set you back to "out of the box" state so no customizations will be present. I would like to know if that helps. Also, please temporarily turn off your firewall and security software as well as the UAC in Windows.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
Per chance are you using Dropbox?
It appears DropBox came out with an update over the weekend that may cause issues opening files when using older versions of Autodesk products. We have heard from our customers that the issue may present as:
-          Crashing
-          Freezing
-          Lagging
-          Product unable to open at all
-          Give an error of “Not Responding”
-          Unable to save new files
This article walks you through removing DropBox and doing a restart. It appears reinstalling Dropbox does not fix the issue, so we advise waiting until a patch is released by DropBox.
Per chance are you using Dropbox? We have been seeing some issues since last weekend that causes such problems.
John Vellek
0 Me gusta
