The EXPLODE command is overused, overrated and used as a catch-and-fix-all-the-bad-stuff method when you run out of options. If stress is what a user feels when he doesn't know what's going on, then the Explode button is frequently clicked when a user doesn't know what's really going on.
Just like Text styles, Mleaders style, Dimension styles, there are TABLE STYLES. A Style, for example an mleader style, has many customizable settings. A closed filled arrow vs. an open 90 degree arrow. Spline vs. straight. A landing vs. no-landing. Your choice of fonts and text height. And many, many more. Instead of setting those parameters in the Properties Palette each time the mleader command is used, you can create an 'mleader style' that applies your, or your firm's, customizations. You could say an mleader style stores your customizations so you may call them up whenever you need them. Storing and retrieving the nit-picky stuff ensures consistency, lets you draw efficiently and enables your work product to present a high level of professionalism.
An individual user can easily switch from one mleader style to another simply by switching styles. A firm can easily update a company standard so all team members operate on the same level.
Whether mleader style or TABLE Style, a Style is considered a best practice. Without Styles, you'll resort to using a default table then applying overrides to that table in the Properties Palette. Establish one or several Table Styles, e.g. a legend style, a parts schedule, a table of contents, and you'll be fine. Dismiss the importance of Table Styles and your drawing will be clunky and have no STYLE.
Chicagolooper
