TABLE LOCKING - FORMAT
RockyBrown4134
Message 1 of 8
RockyBrown4134
When I create a Table, and select locking, content and format, I can still pick the grips and re-size the table. Is there something I am overlooking? Is there another way to lock the formatting, so the cell sizes will not change? My assumption is that I should not be able t change the size or shape of the table.
Thanks.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Resizing has nothing to do with CONTENT (what is inside the dell) or FORMAT (what the text inside the cell looks like).
Same in Excel, you can resize all day long with the same settings.
Message 3 of 8
RockyBrown4134
Thanks Dean,
I did'nt think about it in that scenario.
Could this be a valid wish list item? Or has it been adressed in AutoCAD 2013, 2014?
Rocky Brown
Message 4 of 8
pendean
Community Legend
Community Legend
Sounds like a good wishlist item to me: I'd vote for it.
Message 5 of 8
mgalicki
I have a table that is locked & I can't update it?
The lock icon & a chainlink icon appears when I hover over it?
I need to unlocki it to updated it.
Any ideas?
mgee
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
Message 6 of 8
mgalicki
O.K. I'm thinking I need to unlock all the cells to get the table unlocked?
But still having issues, I can only "update sheet list table" (1) time then this option disapears from the drop-down menu?
I'm thinking it's a BUG.
mgee
Autodesk MEP 2019
Message 7 of 8
I am having the same issue. The locking symbol will not go away even when I select the whole table to unlock everything. I need to ad extra rows for sheets that are coming from another firm. Why is the table format staying locked? Is there a setting that needs to be changed? I'm working in Civil 3D 2018.
Message 8 of 8
mgalicki
You need to pick on (1) cell and unlock it first, then you can pick all the cells & unlock them.
I hope this helps,
Mark G
Autodesk MEP 2019
