TABLE FUNCTIONs
TABLE FUNCTIONs
grobnik
TABLE FUNCTIONs
grobnik
Hi to everybody,
I'm asking a question to this forum about table function.
I'm searching a function like EXCEL IF, I mean:
- I have a table with 3 cells, the first contain a calculation value (numeric), the second contain a comparison value, in the third should contain a word "TRUE" or "FALSE" if calculated value is greater or lower than comparison value.
Is there a standard autocad function able to do this ?
I have a lot of drawings containg data.
schurthing
grobnik
Thank you so much,I'll test.
Sincerly I never used field or or formula inside table. So I didn't know about "IF" function in Autocad Table
Usually I developing Macro by VBA, but in this case I cannot due to drawing shall be used by other people without developing skills.
But looking better to the links seems to be an external application not free of charge... instead I'm search a standard autocad function.
pendean
Community Legend
Community Legend
AutoCAD's TABLE functions are not comparable to Excel's: if this is a dire business need, do all of your table work in Excel then link it into your DWG file(s) instead.
or purchase that 3rd party tool you noted as having found.
