Table Driven Dimensions
e.sharkey
Observer Observer
e.sharkey
Observer
Observer
Hi, I am attempting to use the values within a table to drive the dimensions of a drawing. Basically, the values entered in the table will change the actual dimension of the drawing automatically. I'd like to have a each specific dimension linked to a cell in a table. When the values in the table cells are modified, the drawing will adjust to match. Is this possible? Thanks
pendean
Community Legend
Community Legend
What exact software are you using, and what version software is it?
e.sharkey
Observer
Observer
Hi Dean,
I'm using Autocad Mechanical 2015
GrantsPirate
You can do that with Parametrics and the Parametric Manager.  Set Annotation Contraint Form so the dims will show and print, CCONSTRAINTFORM from the command line or pick from the Ribbon to set that.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
