Tab Selection not displaying
Message 1 of 9
Hey,
I've noticed im getting this issue a lot, is there anyway to avoid this happening?
Everyday I have to open numerous drawings assosicated with a single project, often when I load numerous drawings (19 here in total) via a drag and drop method, some of the drawings become lost within the ribbon?
It would seem that the arrow used for selection of tabs when there are too many open, which is normally in the far right hand side dissappears. I work on two monitors, is this something to do with it?
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
have you considered using SSM (Sheet Set Manager)? It's a better method to manage project-specific files IMHO since you really and truly do not need ALL of them open ALL the time, just the ability to jump to the one you need quickly.
Message 3 of 9
Hey,
well..very often i will open 20 drawings for example, change a single reference then save all, publish and close all.
Still, this doesn't explain why im getting this weird display error.
Any Ideas?
Message 4 of 9
nestly2
Seems like there might be something odd going on with the right edge of the AutoCAD window.   Have you tried resizing AutoCAD down then re-maximizing it?
Message 5 of 9
I restarted CAD and its started working now, But previously I tried re sizing & 'CleanScreening' (ctrl+0) but this didn't work, definitely weird.
Message 6 of 9
Light_Guy
I have run into this as well. Only happens every now and then and there does not seem to be a cure for it, other than closing and reopening the software.
Paul Hamor
Senior Designer/CAD Manager/Data Manager
"Always Good Ships!"
Message 7 of 9
Great stuff,
Is there any way in which we can report this bug officially? No doubt they are already aware, but still, it needs to be raised.
Cheers
Message 8 of 9
pendean
Community Legend
Community Legend
Message 9 of 9
ВeekeeCZ
You can add the "Switch windows" button from View Tab to the end of your Home Tab.
