System Variable Monitor not opening
Whenever I try to open the System Variable Monitor, or run the SYSVARMONITOR command, nothing opens up.  Instead, AutoCAD freezes until I press Escape.
It's not behind any windows or on my other screen; It doesn't appear to open at all.
I've had it working before as I use it all the time.  Does anyone know how to get it back?
cadffm
-It's not behind any windows
ok
-or on my other screen
 ok
 ok
then the dialog is outside your visible screen(s) 😉
[ESC]
[ESC]
[ESC]
Command: SYSVARMONITOR
[ALT]+[SPACE]
[M]
[Arrow Key] <- one of the REAL Arrow Keys, not one from the num pad.
NOW you can move your mouse/cursor around and you will see the dialog.
If it not works by the first time, try it with a visible non-fillscreen window.
The windows calculator for example, or the AutoCAD RENAME dialog..
Sebastian
That did it! It was waaaay off the screen to the right.
Thank you!
