“Synchronize multiple-scale positions” for multiple objects in one go,
JamaL9722060
JamaL9722060
I couldn’t figure out if there is a way to “Synchronize multiple-scale positions” for multiple objects in one go (attached). Or, otherwise, do I need to synchronize them one by one?
Thank you
Best
Jamal
Jamal Numan
nestly2
I just answered a very similar question in another topic, but I can't seem to find it.
Change OBJECT_MTEXT to OBJECTS_MTEXT in the CUI Shortcut menus
JamaL9722060
Many thanks nestly for the help.
I have applied it but sounds that I’m still unable to select more than one object to synchronize them (attached).
What might be my mistake here?
Jamal Numan
nestly2
Text vs Mtext.
Repeat the same for TEXT Object menu  that you did for MTEXT object menu.
I'm really not sure why AutoCAD isn't configured that way by default :confused:
JamaL9722060
Thank you very much nestly2 for the help. It works like a charm (attached).
Best
Jamal
Jamal Numan
ChrisWebster
Wanted to say this works for blocks too. Changed the "Block Reference Object Menu" the same way. I have been looking for a way to synchronize more than one, multiple scale blocks for a while, and finally found it. Thanks for this.
JamaL9722060
Thanks Chris
Best
Jamal
Jamal Numan
