AutoCAD Forum
Synchronize call commands in AutoCAD versions before 2015
2 REPLIES 2
dali0312
95 Views, 2 Replies
   I can use the Command method of Editor to synchronously call commands in AutoCAD 2015 and above versions. However, there is no replaceable method for use in versions below 2015.
  May I ask if anyone has a good solution?  Thanks.
2 REPLIES 2
imadHabash
in reply to: dali0312
As much as i know that AutoCAD versions prior to 2015 don't support the synchronous command method provided by the editor class. You may need to use .NET Transactions or using external tools like VBA macros, LISP scripts, or third-party automation libraries to control AutoCAD in older versions.
Imad Habash
dali0312
in reply to: imadHabash
谢谢你的回复。我使用 .net 语言并尝试使用 acedDommand,但它并没有非常清楚地解决问题
AutoCAD Inside the Factory
