Announcements
Symbol
Symbol
Hi does anyone know how to find the 'symbol' tool under 'text editor' in AutoCad 2018...its not on my Annotate ribbon..
Much obliged
imadHabash
as i understand your need ... you may need to click @ symbol from the mtext editor see below image ) .
Note : make sure that MTEXTTOOLBAR is set to 1 .
Imad Habash
Alfred.NESWADBA
Not within the annotate ribbon, but when you double click the MTEXT object to edit it, AutoCAD shows up the "TextEditor" ribbon, and there is the list of symbols available. Just to make sure ... therefor you have to be in the edit mode of the MTEXT, maybe that's what was missed?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
HI
If it is Single line Text, you will never get Symbol option.
For this case, you need to insert symbol in another MTEXT and do copy Paste.
or Type Symbol code (Example for degree symbol --> Type %%d)
or Convert it to MTEXT by TXT2MTXT command.
If it is Mtext, Do Right Click  and Select Symbol option
or you can also use, previous comment"s procedure..
Thank you very much for you help
Cad learner
Cad Learner
