sweep isnt working (unable to sweep )
darenrr
darenrr
Ive tried just about everything to get this thing to sweep  any help would be appreciated..
I have attached my file
sophia_lee
hi @darenrr
There was an error in the drawing, so fixed this error with AUDIT(y) command enables to sweep.
Please remember to join to base shape to reduce the segments.
Please "Accept it as solution" if this answers your question. thank you,
Sophia, Lee
Sr Technical Support Specialist
Customer Technical Success APAC
I have tried to get this thing to sweep but I don't know what to do about error code 85007. So, any help would be appreciated.
Patchy
Looks like that triangle is bigger than the space between the helix so it overlapping when sweep. Autocad can't do that.
gts9198
i have had the exact same errors. i started to reduce my thread form 0.01mm at a time for a 2.0mm pitch m14 custom thread.. the largest triangle i could get to revolve was 1.88mm, talk about a basic program that flips when overlapping. maybe they should write the code to allow overlapping, after all an object can be extruded into another.
i tried to use fusion 360 and that sux too. just complete garbage when it sweeps... for a programs that could be used for custom threads all the time you would think its a walk in the park. after all pro desktop could sweep any shape along a path and not flip its lid...
