Sweep Error Code Number #55000
edwardlim8
edwardlim8
I have a 3D Polyline and a circle(radius = 9). I need to use circle to sweep along 3D Polyline path, but I get an Error Code#55000.
However if circle radius >= 9.7, it works.
May I know why there is difference between circle radius 9 and 9.7?
Bellow is my 3D Polyline coordinate:
X,Y,Z
3307.8465,166.9,228.6
3307.8465,166.9,275.082
3307.8465,166.9,279.4
3307.8584,155.72401,298.196
3307.87624,138.96002,313.69
3307.90436,112.54403,328.93
3307.94356,75.71405,335.788
3308.00905,14.18297,323.47667
3308.035277,-10.457733,316.211623
3308.0743,-47.12107,305.40183
3308.13955,-108.4251,286.56499
3308.2048,-169.72913,267.72815
3308.27005,-231.03317,247.62131
3308.33555,-292.56425,224.21138
3308.4008,-353.86828,200.04053
3308.46605,-415.17232,175.86969
3308.5313,-476.47635,152.20685
3308.59655,-537.78038,129.30601
3308.66204,-599.31147,109.19808
Valentin_CAD
@edwardlim8 ,
Posting your drawing will increase your chances obtaining a solution.
Provide the version of AutoCAD?
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Valentin_CAD
@edwardlim8,
FYI - I was able to generate your 3D Polyline Coordinates and SWEEP a circle of Radius 9, without any errors.
Emilio Valentin
edwardlim8
My AutoCAD Version is 2019
Below is my drawing. Thanks a lot for your help!
Valentin_CAD
@edwardlim8 ,
To resolve your issue, SWEEP from the other end of the 3DPolyline.
Follow these instruction:
  • Copy the 3DPolyline to the side.
  • Draw a circle, say of Radius 35.
  • Sweep along 3DPolyline
  • Type UCS and select Face
  • Select the end face of the circle and accept. (Take notice of the X,Y,Z)
  • Draw a circle with Radius of 9 and SWEEP.
Emilio Valentin
edwardlim8
Thank you very much for your help! Your method works.
And from the solution you provided, I am wondering that when I draw a 3D Polyline, If I start drawing from the end to starting point, I can use SWEEP directly!
But I'm still very curious about why SWEEP can't be used directly but need other methods
