Hi
I am using CAD 2012 and have a utility drawing where the flow diection arrows for the drainage do not relate to the actual flow direction, I believe this may be due to the direction the data was surveyed in.
An example of the linetype text for surface water is a solid line followed by a gap with SW and an arrow for direction ------ SW > ------
Was wondering if there is a LISP command to swap the start and end points of multiple polylines so that I can select all the polylines with the flow direction arrow pointing the wrong way and make them point the right way. I know that this will cause the text to appear upside down in older versions of CAD but I don't consider that and issue, however if there was a way to keep the text the right way up in versions as old as CAD2004 that would useful.
Also the routine would need to work with a polyline that has more than 2 points as some of the polylines go long distances and so have mulltiple points.
Hello from France
+1 with rkmcswain
You can reverse pline since ACAD 2010 (if I remember well) but only one by one !
Do you need to reverse many plines in one operation ?
Patrice BRAUD
No, it will process multiple entities at once.
Command: REVERSE Select line, polyline, spline or helix to reverse direction: Select objects:
Hello rkmcswain
You are RIGHT and I am a "stupid" boy !
I was focalized by CLICK on ONE Pline then right button then Invert ...
Regards to Mr REVERSE !!
Patrice BRAUD
@Anonymous wrote:
Was wondering if there is a LISP command to swap the start and end points of multiple polylines so that I can select all the polylines with the flow direction arrow pointing the wrong way and make them point the right way. ....
Even in the later versions of AutoCAD that have the Reverse command, it's limited to a few entity types. If you need to do this with other types, or if you're in an older version that doesn't have the Reverse command, try this. Its ReverseDirection.lsp file has the RD command, which works on more entity types than AutoCAD's Reverse. [However, while you can reverse as many things as you want in one running of the command, you do need to go around and pick each one individually, for reasons explained at that web page. But it also lets you Undo individual reversals within the command, without undoing all of them, in case you pick one you didn't mean to reverse.]
