.sv$ wont open
.sv$ wont open
.sv$ wont open
I found my .sv$ temp files in the C drive, I changed the extension to .dwg and nothing happened.  Another thing I noticed is in Windows explorer the extension on my autocad drawings don't show the .dwg, are these issues related.
SeeMSixty7
I would go ahead and set your explorer to show file extensions for known types. There should be under File->Options View Tab a toggle for "Hide Extensions for Know file Types". Make sure it is unchecked. The browse to see if the extension is in fact .dwg for the file you mentioned.
ara_neresesian
HI
if in the explorer the "hide extension" is on  you cant rename it  currently.
maybe your rename it with original extension  like this  "cadfilename.dwg.sv$"
if you turn off  the "hide extension" your file must be cadfilename.dwg
the icon should be changed .
by the way cheek the  file size,it must  to be same size  as your  main file ,not zero
you can open the second one  ,not the first one.
good luck
