Anuncios
Surface Area of 3d face
No aplicable
I have a dished end and i wish to find what the inner surface area is. I have created a model of the end, whats the best way to find the surface area.
I have been told to explode the model and pick on the suface but this does not seem to work.
Autodesk inventor seems to have the same problem.
Its a fundamental requirement when one wants to apply pressure or even to find the surface area when painting etc. See attachment
Any suggestions please.
0 Me gusta
Responder
Soluciones aceptadas (1)
16.070 Vistas
11 Respuestas
Respuestas (11)
imadHabash
you can do it by SOLIDEDIT  copy faces command ( see attached ) then by Properties dialog.
Good Luck..
Imad Habash
0 Me gusta
No aplicable
Thanks for the reply, I have tried your method ,copied the face but when I go to properties it won't give me the area, I think your method works
on a flat surface but not on a curved surface.
Regards
0 Me gusta
imadHabash
would you post the 3D shape here as CAD file?
Waiting..
Imad Habash
0 Me gusta
No aplicable
Please see attached fil as requested
Regards
0 Me gusta
imadHabash
HI,
after copy face use MEASUREGEOM command to get area.is it ok!!
Command: MEASUREGEOM
Enter an option [Distance/Radius/Angle/ARea/Volume] <Distance>:
Imad Habash
No aplicable
No
Its still a problem.
Regards
0 Me gusta
imadHabash
HI,
you wrote " NO " this is for a wrong area number exist or the area doesn't appear?
Imad Habash
0 Me gusta
No aplicable
I did try your measuregeom command but it's not going to work on a curved surface, thanks for your help.
Regards
0 Me gusta
Kent1Cooper
Solución aceptada
Is that dish Solid of a known constant thickness?  You can get its volume with:
  (vla-get-volume (vlax-ename>vla-object (car (entsel))))
If you divide that by the thickness [or get a routine to do it], that should give you the surface area.
Kent Cooper, AIA
0 Me gusta
JDMather
@Anonymous wrote:
Autodesk inventor seems to have the same problem....
Autodesk Inventor does this just fine.
In fact, you marked Inventor as the solution.
http://forums.autodesk.com/t5/inventor-general-discussion/surface-area/m-p/6508172#M609415
Inventor will easily give you the area of an individual face and the total area (iProperties) of the entire part.
0 Me gusta
carartur16
Hello
After having copied the surface of the solid with the command SOLIEDIT.
You can call the AREA command to know the area of this entity.
