Super Laggy DWG file
aligalaxy_stars
New Member
aligalaxy_stars
New Member
New Member
My father's DWG file is experiencing severe lag issues. Initially, I thought it might be due to his PC, but the problem persists even on my high-performance setup (13600k + RTX 4080). Interestingly, the issue isn't related to the file's size; larger DWG files run smoothly without any problems.
It appears the lag is connected to the sections my father added to the DWG file. He copied and pasted portions of the original DWG sheets and worked on them, but I can't figure out how or why these edits are causing such significant performance issues. The lag occurs during any action, whether it's selecting, deleting, drawing, or performing other tasks.
If I delete the part my father created, the problem disappears. I've tried using AUDIT, -PURGE, and other similar commands, but none of them have resolved the issue. Does anyone have suggestions for troubleshooting or fixing this?
I sent u the file if u want u can check it for urself!
paullimapa
Somehow parametric constraints were applied to all the objects.
So I used the DELCONSTRAINT command to remove the constraints from ALL objects. Now everything moves faster....
FYI: There's also this object with a LINE way up above the other objects:
Paul Li
IT Specialist
@The Office
aligalaxy_stars
New Member
New Member
u helped us a lot much appreciated! i dont know what it is and how we enabled it btw!
If u dont mind can tell me also why i can not delete any of the layers?!
paullimapa
You're welcome...but not sure what Layers you're trying to delete but if there're Blocks or objects on those Layers then you won't be able to delete them.
Using the PURGE command you can see what Layers you can delete/purge:
Paul Li
IT Specialist
@The Office
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
