sudden error with 3200 x 1800 display resolution
No aplicable
I recently updated to Windows 10 and autocad was working well.
The next day, I started having resolution problems, where the command line (and some parte) are weirdly HUGE:
http://s12.postimg.org/m3l8w5isd/autocad_resolution_problem.png
I even tried this fix I used in Windows 8.1: http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
But it's not working.
I'm a bit desperate as I'm not good at coding or stuff yet I find no easy solution for this problem.
I saw this link too: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gr...
Tried them, yet it's not working. The first step is impossible otherwise I don't read anything in the computer.
Edit: Just discovered this post: https://forums.autodesk.com/t5/autocad-lt-general-discussion/high-resolution-display-for-lt-2015-and...
Is this real? I'm not going to be able to use autocad properly in this recently purchased computer for at least a couple of years?
0 Me gusta
Responder
Soluciones aceptadas (1)
733 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Solución aceptada
It's for real.
BillGlennie
Thank you for your observations on the appearance of AutoCAD on high resolution displays. The development team is looking for comments about your experience with setting the Windows display scale to 150% or more, to accommodate newer monitors. Please take this quick survey (5 minutes), if you have tried to use AutoCAD this way.
Thanks in advance for your feedback.
Bill Glennie, on behalf of the AutoCAD Team
Bill Glennie
AutoCAD Team, including Architecture and MEP
Autodesk, Inc.
0 Me gusta
