Subtracting array from solid
Hi!
I have the following issue:
I need subtract from big cylinder 20 small cylinders (the drawing is attached)
I created array of 20 cylinders, when  I try to subtract the autocad doesn’t see the cylinders as solid,
So I have to explode the array,
But then I should select them one by one.
If I try to use quickselect autocad doesn’t allow me to do that, since quickselect  is not transparent command.
All ideas are appreciated.
Thank you in advance.
I use autocad 2012.
Patchy
That's the way it works,
Explode it to make multiple of solids then use GROUP command and group P for previous, after that use SUBTRACT.
thank you!
I will try that!
