Stuck in layer notification warning
ties.degruyter
ties.degruyter
I am trying to print a detail in my drawing.
But I am getting an error message like below.
If I click no I get the same error again.
When I click yes, I first get the error message below.
And then again the first.
It seems like I'm stuck in some kind of loop.
Can someone help me with this?
imadHabash
Try to do the follow :
  • For the active drawing, change the system variable LAYERNOTIFY to 0 (zero) or click the Settings button in the upper-right corner of the layers palette and uncheck "Evaluate New Layers Added to Drawings." To turn off the notification for all drawings, change the system variable LAYEREVALCTL to 0 (zero).
  • Clean your drawing from all unwanted items .. Purge , _purge ( Regapps ) and Audit commands .
Imad Habash
ties.degruyter
The problem is that I can't type anything into the command bar or click anything anymore because of the layer notification warning.
pendean
Community Legend
Community Legend
@ties.degruyter Open AutoCAD in a blank empty file.
Do what is suggested by others.
Now open your problem file using RECOVER command. QSAVE after its done.
nthorsten
Just had success clicking "enter" repeatedly as fast as I could about 20x. If you do it really fast, you can execute plot before the "layer notification warning" dialog box has an opportunity to come back up.
cadffm
Do you really use(want) this feature?
Why not disable it in your file
Sebastian
