Stubborn "Missing Plot Style" - Informational
timothy_crouse
timothy_crouse
A tip when you are hunting down a Missing Plot style in a Named Plot Style Dialog
Look in blocks with attributes and verify the attributes are set a known good plot style or
set to by layer.
An attribute assigned to a previous plot style will hang onto that setting even though you may have to change the associated layer to the current plot style outside the block.  A con of the universal use of attribute assignments.
Hope this tip saves someone some time.
Best Regards
-Tim C.
[The subject line of this post has been edited for clarity by cheryl.buck to include "- Informational"]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @timothy_crouse,
Thanks for sharing that tip with the community!
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
