Stretch Command not showing line length
96eric1
96eric1
Hi All
I'm having a problem with the stretch command thats similar to when dynamic input is turned off for drawing lines. The problem being normally when I go to adjust a line length via stretching it would show to overall length of the line as well as angle and stretch amount. However I'm not sure how but I must've turned this off and now it only shows the stretch amount and angle of the line.
Would anyone be able to tell me whats happened here? Would be greatly appreciated.
EDIT:
I've solved the issue, turns out i had 'Enable Dimension Input where Possible' in Drafting Settings turned off somehow
Valentin_CAD
@96eric1 ,
Glad you were able to resolve.
For the benefit of other, here is a visual.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
