Anuncios
Stretch a 3d object from midpoint
No aplicable
I am trying to make the tube longer without changing the ends. Any help would be greatly appreciated.
0 Me gusta
Responder
604 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
Which type of object is it?
"3D object" is not enough information, it could be a 3D-Solid or some surfaces or a block (or multiple ones)?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
Thank you for you reply. I have attached a copy of the drawing. It is a 3D Solid.
0 Me gusta
Patchy
Make a copy, slice a piece of it in the middle, butt them up then union?
No aplicable
I was looking for a solution that would allow me to more easily adjust the length rather than having to sum the 3 lengths and line them all up again as I have numerous drawings that are nearly the same but with varying lengths and bores.
0 Me gusta
Patchy
Some shape can be stretch by holding down the ctrl button, click on the egde and stretch, but some can't.
0 Me gusta
Alfred.NESWADBA
I would then separate the objects, having a connector object and a pipe. The pipe alone can be modified in length either by using _SOLIDEDIT or by creating a block from that object and modify the block scale value that corresponds to the length.
- alfred -
Alfred NESWADBA
0 Me gusta
