- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have no idea how this problem occured.
I was literally working in AutoCAD when I opened my UI changed.
Everything I highlighted for some reason was now dashed, highlighted objects did not glow, everything had an extra line thiness and super pixilated feel. So I closed out, restarted my CAD & my computer and that one file still had these issues. Even worse, suddenly all of my lines that had a thicker global thickness than standard were suddenly outlined?!
It's filled - see my screenshot below.
The line is filled.
It's a poly line yes, but even exploded it doesn't change anything.
It's still outlined in white.
Only one file, I don't know why.
Running a purge & audit didn't fix it either and it's only my computer. Coworker's computer? No issue. Other files in MS? No issue.
I cannot select the lines. I cannot just redraw them either. I checked the layers, no issues.
So I reset my AutoCAD, upset, to default settings via the start menu option thinking it would help, nope. Same issue. Same file. Highlights back to normal, but this file, this stupid stupid file.
I think my CAD is haunted. This isn't my first experience with strange white lines in my autoCAD.
Please help.
It's killing me.
