Stop AutoCAD from loading apps at startup
piermattei
piermattei
So I installed Projectwise version 10....
Now autocad will not start, cashes before I can get to menus or command line to disable intergration. No way to disable integration within projectwise environment.
How can I disable loading?
piermattei
P.S. I average 10 error reports a day to autodesk, for the past ~15 years (as long as they have had the service). One day, a service tech called me!
dgorsman
Find the demand-load setting in the registry for the ProjectWise ARX file, and change the load control flag to "0".
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Alfred.NESWADBA
You might try to change the start-icon of AutoCAD and add the parameter /safemode (>>>details<<<).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
