STL Output for Makerbot
jlucasemail
jlucasemail
There are several separate objects in my drawing which will export as STL individually but if I select more than one object none are exported!
All are co-planer (Z=0 for the base), no overlap, positive X-Y coordinates.  Since they export one at a time assume they are watertight.
Autocad does create an stl file nothing is imported to Makerbot
Alfred.NESWADBA
Please upload your drawing so we can test it on our workstations.
Show us the STL file too, just to know if we can see objects.
Also necessary to know:
  • which version and service pack of AutoCAD do you use?
  • do other files work well with exporting?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jlucasemail
Solved. I'm working in inches and a single object automatically uses 2540 scale but not multiple objects which are not visible. Have to manually set scale
