AutoCAD Forum
STL files resolution
14 REPLIES 14
Message 1 of 15
27708 Views, 14 Replies
When I export a 3D solid into a stl file, curved surfaces are approximated by several straight faces. I suppose it happens during the conversion. I want to have something smoother so is it possible to change the resolution of the stl file? Is there a command for that?
I use Autocad 2017.
Thank you,
14 REPLIES 14
Message 2 of 15
Patchy
There is no option to tweak stl when export from autocad.
Message 3 of 15
Alfred.NESWADBA
turn FACETRES to 10 (max value, lower it if your file is too large).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 4 of 15
john.vellek
Hi @Anonymous,
How is this issue proceeding? Did you get the answers here that you needed? Please post an update.
John Vellek
Message 5 of 15
john.vellek
Hi @Anonymous,
Did this get worked out?  Here is an AKN Article that describes in more detail, the suggestion offered by @Alfred.NESWADBA
John Vellek
Message 6 of 15
in reply to: Alfred.NESWADBA
Gracias, tenía el mismo problema y dudaba si era cosa de AutoCAD o de mis programadas de delaminado 3D. Ahora sé que el fallo era del AutoCAD al exportar a STL y lo he solucionado de manera sencilla y rápida. Muchas gracias
Message 7 of 15
My faceres was set to 0.5, changing it to 5.0 solved sovled my problem & my 3D print is so much nicer now; I suspect setting it to 10 will make it superb 🙂 ... thanks Alfred
Message 8 of 15
I'm getting something weird.
Facetres=10
Facetdev=1000
Shape in Autocad
Shape in Chitubox (my slicer)
I've export several items that look normal in the slicer AND printed perfectly fine.
This one clearly has something wrong with it!
Message 9 of 15
a short follow-up: I sliced the object and exported the 'halves' by stlout.
the 'bottom' half (left, with the hole) looks fine, but the top half (right, upside down) is jagged. same setting and exported seconds apart.
Message 10 of 15
Alfred.NESWADBA
>> Facetdev=1000
Which type of AutoCAD do you have? Because Vanilla AutoCAD does not have this variable.
Even if you have Civil 3D (or any vertical which supports this var) a smaller value creates better curvature, not a bigger value.
The only reason I could imaging is that the objects are created at high coordinates and after slicing one of the objects reached a limit.
If FACETRES does not create a really round object (which STL can't, because it contains triangles and no real curved objects) you can create better result by scaling the object you have to a bigger object in AutoCAD, then export to STL and later in your slicer scale it back.
But take care, the number of triangles could kill the performance of the slicer, slicing will take much more time then.
- alfred -
Alfred NESWADBA
Message 11 of 15
Civil 3D 2020, I've tried high and low values of facetdev with no difference.
Object base was way off near my local state plane coordinates!! How that happened, I have no clue.
Moved everything to 0,0,0 and it fixed itself!
Thank you Alfred!
Message 12 of 15
thank you very much :d worked like a charm
Message 13 of 15
It worked perfectly, thanks!
Message 14 of 15
Worked like a charm! Thanks!
Message 15 of 15
That solved the issue for me - thank you so much. I was going crazy I could not find a solution anywhere.
Forma Design Contest
